lefty loosy righty tighty or?
Discussion in 'Tech Q&A' started by DREDD, May 3, 2013.
  1. DREDD
    DREDD Active Member
    Jan 4, 2013
    191
    27
    victory judge
    o2 sensor's on a 13 judge?
    LEFT HAND OR RIGHT HAND THREAD?
    thx, DREDD.
  2. tarzan
    tarzan Member
    Apr 29, 2012
    235
    8
    Chandler
    Victory Kingpin
    Ive never seen a LH threaded 02 sensor. I haven't removed mine on my CR though. It should be RH.
    LH threads are usually only used where they have a propensity for unscrewing in normal use due to function of the part in it's assembly. I make a lot of threads in my work, mostly RH, and maybe 5% LH.
  3. DREDD
    DREDD Active Member
    Jan 4, 2013
    191
    27
    victory judge
    just checking. the o2 nut bit is notched.
    i know what you are saying, thing's like air fitting's andliquid gas fitting's, usually made of brass, have lefthand thread's.
    thx, tarzan.
    DREDD.
  4. dsjr70
    dsjr70 Well-Known Member
    Oct 8, 2008
    12,241
    39
    Sunny Central
    08 Vegas Low x 2, Vegas LE # 001, Cross Roads LE # 001, High Ball, Vegas 8-Ball, Cross Country, Vision, Cross Roads
    Standard thread design on the 08 so I assume it still is.
  5. 1stVictory
    1stVictory Well-Known Member
    Feb 14, 2012
    3,958
    629
    Edmonton, AB
    2012 Pearl White CC Tour
    What brand of American autos used left hand threaded nuts on their cars?
  6. tarzan
    tarzan Member
    Apr 29, 2012
    235
    8
    Chandler
    Victory Kingpin
    Chrysler for one.I know they use to use left hand wheel studs on I think the right side.
  7. Witchdoctor
    Witchdoctor Well-Known Member
    Feb 10, 2009
    3,013
    224
    Warren
    Jackpot
    Turn it counter clockwise and it will unscrew. They are really tight.
  8. vision_nut
    Aug 15, 2011
    5,543
    449
    vision
    hardware store sells Liquid Wrench buy some and start soaking the 02 threads it will be a big help to you.
    If you ever change exhaust headers the Liquid Wrench bill be great to help loosen the flange bolts
    Bythe way its cheap and will last a lot of years
