Kingpin tank removal
Discussion in 'Victory General Discussion' started by LAYNE, Jul 19, 2012.
  1. LAYNE
    LAYNE New Member
    Jul 16, 2010
    79
    Gilbertsville
    Hello Has anyone pulled a tank on a kingpin? Could you guys help me out with some things I should be aware of. I have a service nanual and it seems pretty straight forward. Need to get a little more knowledge on depresssurizing it. I know I should drain the tank as much as possible but does it have to be completely empty to do it. I am going with ape hangers and I have to route all new cables, this is why I'm pulling the tank. I think it would be better to route the clutch and get to the throttle housng with the tank off. Thanks for any help you guys can give me! Layne
  2. spider
    spider OT-CAN
    Jan 13, 2009
    1,707
    3
    stoney creek
    2014 Indian Chief Vintage # 718
    Remove side covers, remove drivers seat bolts, remove seat. Remove tank bolt at bottom of tank ( where seat meets tank )remove front tank bolt covers, loosen but do not remove bolts just yet. Lift rear of tank, ( less gas the better ), block with small piece of wood or hold with one hand ( been there done that ) remove fuel line fitting, unhook electrical connector, ( easier with two hands, lol ) remove block of wood, set down carefully, now remove front bolts completly, remove tank trying not to hit tank on risers. Done this a few times now, easy as pie. Edit : Sorry, on " depressurizing ", all I ever did was remove the fitting from the tank, no big gas spray, no issues and I have had my tank off at least three times.
  3. iabob
    iabob Well-Known Member
    Dec 20, 2010
    8,175
    1,299
    Des Moines
    Victory Kingpin and Victory Vision
    It's not necessary to drain or depressurize, you will only spill about a spoonful. Gas weighs about 8lbs per gallon so a full tank is a little heavier than an empty one, but totally manageable.
  4. LAYNE
    LAYNE New Member
    Jul 16, 2010
    79
    Gilbertsville
    Thank for your reply spider. I didnt see anything in the mannual about the electrical connection. just the fuel line and the vent lines. They talk about depressurizing the fuel line whats that about? Thanks again for the reply
  5. LAYNE
    LAYNE New Member
    Jul 16, 2010
    79
    Gilbertsville
    Thanks guys, this helps alot! I feel I should have no problem with this now!
  6. Half_Crazy
    Half_Crazy Well-Known Member
    Aug 23, 2008
    7,500
    1,807
    Great Mills, MD
    2006 Kingpin
    Nope, never, not a single person has done that since 2004... but maybe soon.
  7. spider
    spider OT-CAN
    Jan 13, 2009
    1,707
    3
    stoney creek
    Oops, forgot about the vent lines, might want to pull them also :blushing:
  8. LAYNE
    LAYNE New Member
    Jul 16, 2010
    79
    Gilbertsville
    Thanks the Tank is off!
how to remove 2008 kingpin gas tank
how to remove the fuel tank on a victory kingpin
remove tank 2005 victory vegas
removing gas tank on a victory motorcycle
