Installing Saddlebags on the Judge
Discussion in 'Tech Q&A' started by JerryWawak, May 3, 2013.
  1. JerryWawak
    JerryWawak Member
    May 3, 2013
    282
    14
    Poplar Bluff
    2013 Victory Judge
    I got my saddlebags and installed them last night. The process wasn't difficult. As long as you have the right sized allen wrench and socket you should be good. However I did have an issue with no istructions for one piece. They are Lock and Ride. So you buy the Saddlebags and then you buy the mounting kit seperately. The mounting kit came with good instructions and I was able to mount the studs with little problem. However the Saddlebags themselves came with no instructions at all and they included the latching braket. There was no instructions whatsoever on how to install the bracket. I had to search on the internet to find it. Turns out the back of the rear footpeg bracket has two small threaded holes to receive the bracket. Just put the rubber pads on the bracket to keep tension on the bolts and tighten it up. I wasn't real thrilled with the look of this bracket with the sadllebags off. The mounting studs also were a little moreprominent than I would have liked with the bags off.
  2. dsjr70
    dsjr70 Well-Known Member
    Oct 8, 2008
    12,238
    40
    Sunny Central
    08 Vegas Low x 2, Vegas LE # 001, Cross Roads LE # 001, High Ball, Vegas 8-Ball, Cross Country, Vision, Cross Roads
    Had them on one of my Vegas's and thought the studs were a little out of place. Went with the ghost brackets and have no complaints. The plus is I was able to use any saddle bag with the ghost which saved me a ton of money on something I rarely use. Not sure if thy have ghost brackets for the judge yet.
  3. JerryWawak
    JerryWawak Member
    May 3, 2013
    282
    14
    Poplar Bluff
    2013 Victory Judge
    I'd have to double check, but I thought these were the Ghost brackets. At least that is what the invoice says.
  4. JerryWawak
    JerryWawak Member
    May 3, 2013
    282
    14
    Poplar Bluff
    2013 Victory Judge
    The posts are too bad, the latching bracket is the thing that really looks out of place. Plus it's not flat black. It's glossy with a green tint.
  5. dsjr70
    Oct 8, 2008
    12,238
    40
    Sunny Central
    Are they manufactured by ghost or are they victory lock and ride brackets? Ghost brackets should have come in a gloss black crinkle finish.
  6. JerryWawak
    JerryWawak Member
    May 3, 2013
    282
    14
    Poplar Bluff
    2013 Victory Judge
    The outer most part of the post is a glossy black and grey finish that looks textured. Not sure if that is the crinkle you are referring to.
  7. dsjr70
    Oct 8, 2008
    12,238
    40
    Sunny Central
    Do you have bags with a victory logo?
  8. JerryWawak
    JerryWawak Member
    May 3, 2013
    282
    14
    Poplar Bluff
    2013 Victory Judge
    Yes they are victory bags made for the judge. The lock and ride spools are what are recommended I. The catalog to install it. I'll post a pic later. Getting ready to watch iron man 3 right now.
  9. UK_Paul
    UK_Paul Well-Known Member
    Apr 13, 2010
    1,538
    32
    UK - Herefordshire
    Vegas 2009
    l did the very same thing on my Vegas.
    I think Polaris are missing a trick with this.
  10. JerryWawak
    JerryWawak Member
    May 3, 2013
    282
    14
    Poplar Bluff
    2013 Victory Judge
    I assume the posts stick out so far because they have to leave room for the back rest if you want to mount that as well. If I had a shorter bolt I could leave off the back rest bushings.
  11. Chaz1369
    Chaz1369 New Member
    Apr 11, 2012
    380
    2
    Jacksonville
    2013 Victory Judge
    That is exactly why. the inner bushing is for the lock and ride backrest.
  12. JerryWawak
    JerryWawak Member
    May 3, 2013
    282
    14
    Poplar Bluff
    2013 Victory Judge
    http://img.photobucket.com/albums/v116/Wallwart/AB24333F-D687-4D99-A5F1-F282D6138367-4046-00000B800AC63F59.jpg http://img.photobucket.com/albums/v116/Wallwart/3498189C-303A-4401-BD2B-418356F202D9-4046-00000B7FFEA6439B.jpg Here are the pics of the posts and the bracket
  13. Chaz1369
    Chaz1369 New Member
    Apr 11, 2012
    380
    2
    Jacksonville
    2013 Victory Judge
    wow they are green, dont know what happened there. mine are black and match the bike great.
  14. JerryWawak
    JerryWawak Member
    May 3, 2013
    282
    14
    Poplar Bluff
    2013 Victory Judge
    If I feel crafty I might paint them flat black.
install saddlebags on a vegas
2013 victory judge bags
2013 victory judge ghost bags
2013 victory judge saddlebags
2014 victory judge saddle bags
ghost bracket on victory judge
how do you put saddlebags on a 2013 victory judge
how to mount soft bags on victory vegas
install victory saddle bags on victory vegas
installing victory saddlebags
judge ghost bag part number
