Hi-Flow Air Filter....from Lloydz
Discussion in 'Discussions by Model' started by Monark26, Oct 27, 2012.
  1. Monark26
    Monark26 Member
    Aug 9, 2011
    195
    9
    Katy, TX
    2011 Cross Country (White & Silver), 2013 High-Ball
    I recently installed Lloydz new Hi-Flow air filter and instead of following the instructions I left in place the stock plastic ring that goes around the front edge of the frame above the filter hole. I was concerned about water ingress during rain storms so I cut the stock plastic piece so it fit the new filter, which left in place the rubber seal at the front edge. Since doing this i've seen that others remove this seal to gain HP. My question is has anyone ever had problems with ingesting water during heavy rain after removing the rubber seal?
  2. bikendad
    bikendad Well-Known Member
    Apr 10, 2009
    4,335
    331
    SE Michigan
    2010 Victory Cross Country
    No, I've ridden thru heavy downpours for hours and never a problem. The rubber strip is there for sound reduction to pass EPA regulations. By leaving it in you are really defeating the purpose of the hi flow filter as it seriously reduces airflow. After removing it if you don't have a fuel controller I recommend unplugging your O2 sensors to richen the mixture.
  3. Harrar
    Harrar Active Member
    Oct 23, 2012
    198
    30
    N. Las Vegas
    2012 Hard-Ball
    New to the VOG first time reply, new Hardball: Ok you install a Lloydz Hi-Flow air filter & Controller, You unplug the O2 sensors & you plug the 2 holes on your headers. What do you do with the O2 sensors at tis point? Do you cut the single wire and cap it, or do you follow the wire to it's source & remove it?
    • Winner Winner x 1
  4. Monark26
    Monark26 Member
    Aug 9, 2011
    195
    9
    Katy, TX
    I guess I didn't consider the noise factor. Maybe I should pull the tank again and remove the plastic ring as the instructions say!
  5. bikendad
    Apr 10, 2009
    4,335
    331
    SE Michigan
    Whoa there horsey, you're going way too far. Just follow the wire coming out of the sensor to the connector and unplug it, that's it. There is no need to remove the sensors from the pipes but some do and put a plug in the hole.
  6. Harrar
    Oct 23, 2012
    198
    30
    N. Las Vegas
    2012 Hard-Ball
    that sounds easy enough, just fallow the wire and unplug the sensor. I Didn'd make it clear but yes I do want to remove the sensors and install a plug.....Thank you.....bikendad
  7. dtmmil
    dtmmil Member
    Aug 5, 2012
    178
    2
    Hawley
    I would just unplug them first and ride it to see if its what your looking for before spending the money on the plugs. I unplugged mine and got popping between shifts and on decel, plugged them back in and the popping went away.
  8. Bobbyd85
    Bobbyd85 Well-Known Member
    Jul 26, 2012
    1,461
    83
    92392
    2012 Black Cross Country
    I can't find supporting info so I'm assuming the answer is no, but do you have to oil the lloydz filter and can it be cleaned? Thanks ahead of time.
  9. PrometheusVII
    PrometheusVII Member
    Apr 22, 2010
    400
    2
    Las Vegas
    2010 Cross Country
    You know, some vehicles actually inject water into the combustion chamber to increase fuel mileage and promote cooling. The trick is to inject enough to get the cooling, and increased cylinder pressure from the resulting steam, without extinguishing the flame of the combustion process.
    That said, the trickle that might (and I stress Might) find it's way into your intake during a torrential downpour should just be passed through the combustion process and not even noticed.
    As such, I would (as most here have) just remove the rubber/plastic strip and enjoy the increase inperformance.
    Any counter discussion points?...
  10. stevewithavision
    stevewithavision New Member
    Nov 15, 2012
    3
    2009 Victory Vision 10th Anniv
    You are correct, you do not have to oil the filter until after you clean it. I use the K & N filter cleaning kit, so far so good!
  11. Witchdoctor
    Witchdoctor Well-Known Member
    Feb 10, 2009
    3,016
    213
    Warren
    Jackpot
    Remove the plastic ring like the directions say.
  12. Monkeyman
    Monkeyman Active Member
    Jun 11, 2012
    2,935
    14
    Peru
    None :(
    I had an open intake on my Nomad (big round filter on the SIDE of the bike). It rained, water got in. I never had any issues.
  13. Bobbyd85
    Jul 26, 2012
    1,461
    83
    92392
    received my Lloydz filter today and had my Lloydz VFC for about a week, been waiting so i can do them both at the same time. im pretty excited. hope i can make time this week to install them and enjoy the difference.
    [​IMG]
  14. bikerdeano
    bikerdeano Well-Known Member
    Feb 5, 2012
    1,774
    47
    Sherwood Park
    2012 Vegas & 2012 CCT
    Keep us posted on your "before and after" results.
  15. Bobbyd85
    Jul 26, 2012
    1,461
    83
    92392
    wish i could. there is no dyno anywhere near me. but i will let you know my honest thoughts and if my debaffled exhaust quits popping. right now i have it on up and downshift. also after taking the baffles out of my exhaust my get up and go in 5th and 6th gear seem very sluggish around 65-75mph. main reason i got the stuff in the first place.
660333 lloydz high flow air filter
air filter 2016 victory cross country
high flow air filter for victory
installing a lloydz air filter
installing s&s air clear in a 2007 victory jackpot
lloyds air filter
lloydz air filter 2016 victory gunner
lloydz air filter uk
victory cross country air filter
victory cross country lloydz air filter
victory xc high flow air
when to reoil lyods air filter
