Help! Rear Brakes requires pumping!!
Discussion in 'Tech Q&A' started by wfsdno, Apr 7, 2013.
  1. wfsdno
    wfsdno Member
    Aug 26, 2012
    36
    Troy
    2009 Vision - Ice Blue!!
    Rear brakes worked fine last ride, yesterday started noticing pedal was squishy, first pump almost to the floor, second and third started building pressure, but next time, no pressure till pumped.
    Jumped to today, went out to garage,stepped on brake and no pressure, even pumping did not deliver pressure.
    There are no leaks, reservoir is full with clean and clear fluid ( with a touch of yellow).
    Any ideas??
    Thanks!!
  2. ByteN2it
    ByteN2it Well-Known Member
    Mar 15, 2010
    720
    252
    '99 V92C & '09 Vision
    Usually you just need to bleed the front wheel's right caliper lower bleed valve-it's the one between the two banjo bolts , not the one on top.
  3. DiamondDave
    DiamondDave Member
    Aug 19, 2012
    305
    9
    North Texas DFW
    2009 Ness Vision , 2013 Vegas 8 Ball
    Yep Bleed brakes
  4. Barbarossa
    Barbarossa Member
    Feb 27, 2013
    197
    Parts Unknown
    2012 Victory XCT Pearl White. "The Great White"
    Sounds like a bad rear master cylinder.
  5. BenD
    BenD Active Member
    Apr 16, 2012
    280
    40
    Phoenix
    2012 cross country tour
    I agree. Your fluid is going around the seal intead of actuating the piston.
  6. Handyhoward
    Handyhoward Member
    May 28, 2011
    245
    9
    Apopka
    2011 Victory Vision Touring ABS or 2013 Indian Vintage Chief FE #7
    Sounds like a leaking pressure switch... this switch is located up front and can be broken from road debris flying up into the front opening. It's a $15 part and about 20 minutes to replace.
  7. ByteN2it
    Mar 15, 2010
    720
    252
    This is a known issue with the Vision-your master cylinder is not the issue-bleed the right front center valve & it can't hurt to bleed the rear brake to but wasn't necessasary in my case & others. This is a linked system and as crazy as it sounds bleeding at the front center caliper will take care of the problem.
  8. phoenix9
    phoenix9 Well-Known Member
    Mar 28, 2009
    6,136
    81
    Litchfield Park
    2012 Cross Roads Classic Limited Edition #001
    BytN2it is correct. This was an issue on the 2008 Vision and to a very very small degree on the 2009's. I had the exact same issue on my '08 Vision. If you do a VOG search on breaks you should find at least one thread I started on this subject and I got some good advice from Kevin X on this. Ultimately he recommended replacing the line.....although I cannot remember why or his exact reasoning.
    I will do a search and post the link here.
    NOT a master cylinder issue.
  9. phoenix9
    Mar 28, 2009
    6,136
    81
    Litchfield Park
    Here it is....I finally found the thread. Hope this has some information that can help you.
    http://www.thevog.net/forum/thread/8480/039-08-vision-losing-rear-brakes/
  10. wfsdno
    wfsdno Member
    Aug 26, 2012
    36
    Troy
    Thank you everyone! I will start with bleeding the front center, if that doesnt work, move on to the more expensive stuff.
    I appreciate the help!
    Ride safe, Roger
  11. bmwgypzee
    bmwgypzee New Member
    Jun 1, 2012
    5
    oconomowoc
    '99 Excelsior Henderson, '00 HD FLHT, '08 Ness Vision, '10 BMW R1200RT
    I have an 08 Arlen Ness Vision with 24,000 miles. I had this issue with the rear brakes come up last spring after sitting all winter. I tried the usual bleeding of the rear including using a hand vacuum pump to pull fluid from the master all the way back throgh the caliper. I went through 3 resevoirs of fluid and never pulled an air bubble, but only got meager pedal pressure. I only put on 4000 miles last year as the rest of the summer was spent on my new BMW R1200 RT.
    This year the problem is back only worse, there is virtually no pedal pressure. I am gladto have found these suggestions from others, and will attempt bleeding the front right caliper, and if that fails will have to replace the brake line.
    Thanks to all contributors.
  12. vision_nut
    Aug 15, 2011
    5,953
    512
    vision
    Happened once to my 08 bleed center bleeder on front caliper never had a problem after that
  13. wfsdno
    wfsdno Member
    Aug 26, 2012
    36
    Troy
    Worked like a charm!! Took about5 minutes doing it myself. Center plug on right side and BINGO! Now there stiff like a deadman.....
  14. wcato3
    wcato3 Well-Known Member
    Jun 21, 2012
    1,550
    84
    Hopkinsville
    2010 cross roads
    What they all said I would do first......but check to see if the disk roter is bent. It has the same cause as air in the line due to pads being pushed deeper into the calipers. Best wishes and hope it is nothing but air.
  15. SofaKingBlue
    SofaKingBlue Member
    Mar 11, 2009
    752
    5
    Orlando
    '04 Touring Cruiser; '08 Jackpot
    I have a similar problem with my '08 JP, I bled the rear brake twice but there seems to be air getting into the back brake system. No fluid leaks or need to add fluid - just additional air.
2011 vistory vision master brake cylinder
2012 victory vision no rear brakes
bleed brake lines on 2009 ness jackpot
brakesfluiddrippiing fromvictoryvision
how to bleed back brake victory 8 ball
motorcycle rear brake pump kit no pressure at times
parts diagram for 2009 victory vision rear brake caliper
rear brake on victory vision is spongy
rear brakes require pumping
victory vision rear brake cylinder
victory vision rear brakes leaking
why wont my motorcycle rear caliper bleed victory forums
