heated grips from xc tour on a magnum?
Discussion in 'Victory Magnum' started by 3rdElement, Nov 15, 2015.
  1. 3rdElement
    3rdElement Active Member
    Feb 4, 2015
    201
    69
    Castle Rock, Colorado
    2015 Victory Magnum: Magnum Red over Super Steel Gray
    a buddy is removing the heated grip system from his xc tour and they become mine for helping him. Anyone know if its plug and play with the magnum harness? (cause just from my dealings with my trunk audio...im leaning towards it not being fun and easy) btw use the little witchdoctors part to fix my left mirror being lower than my right mirror. 19 dollar part was worth it. 12250151_10153234087677218_3383751466448002487_n.jpg
  2. 3rdElement
    Feb 4, 2015
    201
    69
    11225213_10153153237357218_5336487115423198160_n.jpg just cause....
    • Like Like x 4
  3. Ariesnc
    Ariesnc Well-Known Member
    Dec 19, 2013
    2,812
    770
    Fuquay Varina
    2015 Victory Magnum
    I thought about adding them to my magnum. Let me know if it works. I was looking at buying a set and the try to use different bar ends.
  4. UIWMC
    UIWMC Active Member
    Apr 17, 2015
    403
    217
    Tennessee
    14 Vic XR8ball
    Added them to my xc all the wiring was there plug n play makes year round riding much nicer would b surprised if yours weren't same
  5. sparkn
    sparkn Active Member
    Feb 18, 2013
    603
    112
    Tazewell
    2013 Victory Cross Country Tour
    As a note, when the bar ends are installed on the right side you'll need to leave a small gap. The grips swell slightly when heated and if the bar end is too close the throttle will become stiff and hold its position similar to a throttle lock. If you go too far, a little tap should give enough clearance. Maybe a millimeter is all you need.
  6. Ariesnc
    Dec 19, 2013
    2,812
    770
    Fuquay Varina
    2015 Victory Magnum
    You removed fairing and switch housing ? So everything plugged into the inside of fairing ?
  7. Ariesnc
    Dec 19, 2013
    2,812
    770
    Fuquay Varina
    2015 Victory Magnum
    I see you added the forged engine guards . You plan on adding lowers?
  8. primethious
    primethious Well-Known Member
    Aug 14, 2013
    4,767
    1,232
    2012 Victory Cross Roads
    Thanks for the heads up on the mirror part. I been griping about that thing for a couple years not knowing there was a fix. The hard knuckles on my gloves hits it unless I have the mirror angled upward slightly.
    Time for some Tootsies!
  9. primethious
    Aug 14, 2013
    4,767
    1,232
  10. Chattanooga_Mark
    Dec 25, 2009
    3,174
    937
    Chattanooga
    2012 CCT, Wonderful in white
    3,
    No idea on if the heated grips will bolt on easy peasy or not. I just wanted to say your Magnum is B E A U T I F U L, congratulations on your excellent taste in motorcycles.
  11. firemanjoe
    firemanjoe New Member
    Apr 3, 2013
    26
    24
    2012 victory cross country
    I installed heated grips on my cc. It was all plug and play. I would assume the magnum uses the same wiring harness.
    I would think you should be good to go.
    I still have the instruction sheet from my 2012 cc if you need a copy.
  12. Ariesnc
    Dec 19, 2013
    2,812
    770
    Fuquay Varina
    2015 Victory Magnum
    I installed the heated grips this weekend and it is plug and play on the Magnum. Simply just use the correct color coded wires and that's about it. I will say that you will need to remove the inner fairing to insert the switch housing as well. Other than that it's not to bad. If you have any questions let me know.
  13. 3rdElement
    Feb 4, 2015
    201
    69
    thats great info!
  14. 3rdElement
    Feb 4, 2015
    201
    69
    yes. just finished moving into a new house. so once the dust settles i can use some tax money for the jtd lowers
  15. 3rdElement
    Feb 4, 2015
    201
    69
    thank you very much! i am very proud of this bike and how well it works for being a badass bagger and a great tourer
victory magnum heated gips
