Filler Mods
Discussion in 'Victory Magnum' started by sdmike, Oct 26, 2015.
  1. Dta8995
    Dta8995 New Member
    Feb 19, 2016
    7
    5
    Scranton, PA
    Magnum
    Thank you!
  2. FeTT-X
    FeTT-X New Member
    Mar 8, 2016
    8
    Honda VTX 1800N
    I don't own a Magnum but have my sights set on one. I had just assumed that there would be sissybar options available for it, but from this post it sounds like that is not the case... And if you want one you need to make your own. Is that true?
  3. JamesBond
    JamesBond Active Member
    Oct 29, 2015
    417
    121
    San Diego area
    2015 Magnum/ 2005 Big Dog Chopper
    If you want the ugly stock backrest then you will have to remove the bag fillers. Or do what I did and go custom "GINZ CHOPPERS" sissy bar and leave the fillers, just had to trim the fillers so the brackets would fit, and drill a couple holes in the bag brackets. Look at my picture on page1. My wife leans back on it all day and says she's comfy.
  4. Joe x1
    Joe x1 New Member
    Apr 8, 2016
    2
    2015 Victory magnum x1
    Do you have any pics with the mustang seat on the bike? How did it fit?
  5. justjoe
    justjoe Member
    Mar 30, 2012
    100
    18
    Pelham NH
    2015 Magnum
    when I bought my Magnum they offered an optional victory seat where the backrest is removable and can be used either for the driver or the passenger. It was an $800 Victory seat I believe.
  6. Stealth Junior
    Stealth Junior New Member
    Apr 9, 2016
    2
    6
    2016 Magnum X1 Stealth
    image.jpeg image.jpeg Hope this helps you out. Used a dremel and a jigsaw with some whiskey just in case I had some regret...
    • Like Like x 3
  7. JamesBond
    Oct 29, 2015
    417
    121
    San Diego area
    Nice job! did the same to mine but didn't need to cut as much for my custom sissy bar mounts.
  8. edword
    edword Active Member
    Sep 20, 2015
    242
    77
    cross country & fat bob
    lets see some pics
  9. rigormootis
    rigormootis New Member
    Aug 7, 2015
    7
    You should draw up a couple of templates of this and post it for everyone. Try and scan it at exact size so when its printed it will come out right. I'm sure many people will greatly appreciate it.
  10. Thomasthetank
    Thomasthetank New Member
    Apr 4, 2016
    7
    13
    2016 X-1
    I want a sissy bar just like this....
  11. Stealth Junior
    Apr 9, 2016
    2
    6
    I will do that the next time I have to pull them off. An exact template would not work for all projects I would assume seeing how the width of the cuts varied by an 1/8" from one side to another.
  12. resolaru
    resolaru New Member
    Jan 10, 2017
    10
    Magnum X1
    Thank you for sharing. This sounds exactly like what I'm looking for. Until I saw this, I was actually trying to create my own removable sissy bar back rest that would slip in between the fillers and hook onto the saddle bag brackets.
    Is this easy to remove, or more of a permanent addition? My wife does not ride much, but she needs something on the back. I looked on Ginz's website, but can't seem to find this product. Can you send me the link or give me the exact name? Thank you.
  13. JamesBond
    Oct 29, 2015
    417
    121
    San Diego area
    resolaru, go on Ginz website and pick the style and height of the bar I have the Hardcore height. Then you need the mounting brackets for Victory, give them a call they are very helpful. Once you have it installed you wont even want to remove it! Looks bad ass!
  14. resolaru
    resolaru New Member
    Jan 10, 2017
    10
    Magnum X1
    Thanks again. Your bike does look bad ass. Do you have a cushion that you put on the sissy bar for your rider?
    Also, on a different note - where did you get your lay down license plate from? It looks really good.
  15. JamesBond
    Oct 29, 2015
    417
    121
    San Diego area
    Ginz makes pads for the sissy bar, my wife says it's better for her without it (thankfully) Looks better. Lay down plate is from Vic Baggers
moto guzzi flying fortress sissy
removing seat from magnum x1
