Easy Clutch...Ever Tried it?
Discussion in 'Victory Cross Country' started by ArkieBiker, Feb 8, 2012.
  1. ArkieBiker
    ArkieBiker Member
    Oct 5, 2011
    177
    3
    Searcy
    Cross Country Tour
    I don't have any issues with the clutch on my 2012 Cross Country Tour, but an easier pull is always welcomed...and this one even comes with a chrome clutch cover. So has anyone here used one of these? http://www.victoryonly.com/ACCESSORIES/easy_clutch_plain.htm
  2. shockhappens
    shockhappens Member
    Dec 10, 2011
    114
    23
    Kernersville
    Corry Ness Cross country 117
    That looks cool just to cover up that crappy piece the cable attaches to, that is one of the worst pieces on the bike..........
  3. cabikerdad
    cabikerdad Member
    Aug 3, 2011
    186
    2
    campbell
    12 XCT and 01 V92C
    I have the easy clutch on my XCT. I had one on my 07 kingpin too. never an issue with them. And they do look much better than the stock arm K
  4. ArkieBiker
    ArkieBiker Member
    Oct 5, 2011
    177
    3
    Searcy
    Cross Country Tour
    cabikerdad...so does it actually make the clutch easier to pull..not that mine is that difficult. I am wondering if it will help with the clutch cable fails I have been hearing about.
  5. dragon6
    dragon6 Member
    Oct 22, 2009
    437
    22
    Grand Rapids
    My dealer in Fort Pierce Fl uses one on his demo XCT and it makes a big difference in the pull. He also claims that the clutch cable will last longer.
  6. PrometheusVII
    PrometheusVII Member
    Apr 22, 2010
    400
    2
    Las Vegas
    2010 Cross Country
    That's odd, I read/heard the EZ-Pull is finicky (has to be set perfectly) and if not it will allow your cable to rub (somewhere), causing a premature failure. I was going to go that route, but decided to go with the Hydraulic conversion, easier pull and no cable issues. Haven't ridden it yet (Still in A-Stan till Feb 29th), but the wife said it is much easier and smoother than before. She had to load/unload it to take it to Boca Raton, FL, to get the work (and some other goodies) done. Just mah deuce cents worth...
  7. thibsgary
    thibsgary New Member
    Dec 22, 2011
    91
    Palm Bay
    2005 vegas
    I have one on my 05 Vegas. It is much easier than stock, really matters when stuck in traffic. Kevinx, a few weeks ago when I had him adjust my cable said, they are much easier on the cable, a lot less stress on the cable, but a pain in the but to set up correct. Once they are set they are great.
  8. cabikerdad
    cabikerdad Member
    Aug 3, 2011
    186
    2
    campbell
    12 XCT and 01 V92C
    Yes, the easy clutch makes the clutch lever very easy to pull. As for the cable failures, in my opinion Yes it helps with preventing cable failures. I have not broken a clutch cable since I started using the easy clutch. My first Vic broke a clutch cable every year from the time it was new. It got to the pint that i carried a spare cable. This is before the cable repair kit's they sell now. As for the adjustment....? I have never had an issue with adjusting my clutch cable using the easy clutch. And I've never had a clutch failure on any of my Vic's. I've had 3 been riding them since 2001
  9. GaKingpinRider
    GaKingpinRider Member
    Apr 8, 2011
    441
    2
    Cumming
    '15 Indian Roadmaster
    I have considered one of these for a long time. Lloyd ( as in Lloydz Motorwerkz ) and KevinX talked me out of it as it can apparently cause the clutch to slip...
  10. gregbenner
    gregbenner New Member
    Aug 4, 2011
    191
    SoCal, Jacksonville
    2011 XC
    It appears from the link that thee are for 2007 and PRIOR Victorys.? Specifically excludes Visions, doesn't seem to mention the Cross bikes
  11. cabikerdad
    cabikerdad Member
    Aug 3, 2011
    186
    2
    campbell
    12 XCT and 01 V92C
    I have one on my 2012 XCT. Call the guys at Witch Doctors, they will hook you up don't worry
  12. miles_1
    miles_1 Member
    Dec 17, 2010
    110
    2008 Victory jackpot
    Will it work on with a Hydraulic clutch?
  13. vmi1982
    vmi1982 New Member
    Oct 15, 2010
    25
    Easton
    The clutch assist assembly seems to be a solid unit, but will not work if you have the reverse kit installed. The end of the reverse unit sits low enough that the clutch assist assembly hits the reverse unit before it even gets to normal rest position.
  14. STARVN
    STARVN Member
    Dec 27, 2009
    81
    2
    Southfield
    I have the easy clutch pull on my '10 Cherry XC, I've had it on th bike since 2010 and it makes the clutch so easy. Mine is also all chrome w/the "Winged V" engraved on it.
  15. Blowndodge
    Blowndodge Active Member
    Jan 31, 2013
    695
    157
    Lakewood, CA
    2013 Victory XCT
    This is an old thread but I have one installed on my 13 XCT and it's great. Not that I couldn't pull the lever in but that chrome piece looks nice and I have a wider engagement point that helps in low speed situations! [​IMG]
easy clutch lever victory jackpot
ez clutch victory motorcycle
installed victory e z pull how to adjust
victory cross country clutch relief
victory cross country tour hydraulic clutch vs cable clutch
victory easy clutch review
victory easy pull clutch
victory ez clutch
victory ez pull problem
victory vegas clutch issues
victory vegas ez pull clutch
what makes an ez pull clutch so easy
