dyno results
Discussion in 'Victory Cross Country' started by LVChefCC, Aug 17, 2013.
  1. LVChefCC
    LVChefCC New Member
    Aug 9, 2013
    14
    Orlando
    cross country tour
    2013 CCT 46 miles currently on the clock
    93 degress
    86% humidity
    bassani road rage 2-1 black ceramic coated
    power commander 5
    victory stage 2 air filter
    filter box strip removed
    put down 87.66 at the rear wheel
    Next step :
    Lloyds Cam set
    Lloyds filter
    power commander auto tune (ordered)
  2. 11VICXC
    11VICXC theVOG.net Gold Supporter Gold Supporter
    Jun 21, 2011
    356
    2
    Rochester, NY
    11' Cross Country/14' Indian Vintage #953
    I have the same bike with the same mods cept I'm already using Lloydz HF AF and the PCV/AT. May do cams this fall. Love the looks and sound from the Road Rage pipe by Bassani, I removed the insulation from around the baffle and really like the overall sound improvement.
  3. craigoreo
    craigoreo New Member
    Apr 6, 2013
    3
    2013 XC
    I have the same pipe, PC5, Lloyd's air filter-cams-timing gear... 113hp on the dyno!!!!
  4. 11VICXC
    Jun 21, 2011
    356
    2
    Rochester, NY
    Who did the tune for your bike?
  5. craigoreo
    Apr 6, 2013
    3
    2013 XC
    Fuel Moto in Little Chute Wi, check out their facebook page, they are getting similar #'s on harley's but they are doing full 107 big bore kits,cams,heads....$$$$$$$
  6. LVChefCC
    LVChefCC New Member
    Aug 9, 2013
    14
    Orlando
    cross country tour
    Prior to dynoing my bike I saw some very impressive numbers coming from a set of slip-ons,tune and air filter. I found the answer when I was sitting with my tech who done my pulls, he said watch this... ran zero brake on the dyno and WOT in 6th... I almost **** myself when I saw 107.19 hp!! Then we went back to the standard 20% brake and fifth gear. Just an idea, be careful of some of these parts places with dyno results that seem a lil high, they could have been free braking the dyno
  7. craigoreo
    Apr 6, 2013
    3
    2013 XC
    What were the results of YOUR dyno run????
  8. Ace22
    Ace22 Active Member
    Jan 24, 2012
    418
    57
    Ohio
    '11 Ness Cross Country
    Add the timing gear to your setup, and you will be rockin'. Exactly what I have and putting similar to 11VICXC.Can't go wroing with the Lloyd's cams!
  9. iabob
    iabob Well-Known Member
    Dec 20, 2010
    8,195
    1,307
    Des Moines
    Victory Kingpin and Victory Vision
    A. Break in your motor for a full 500 miles before putting it on a dyno. B. 93 degrees and 86% humidity will show lower numbers than 70 degrees and 50% humidity.
  10. Blazed30
    Blazed30 New Member
    Jul 19, 2012
    529
    3
    Buckeye
    2012 Victory Hardball
    I could easily see you adding some more numbers on your bike after she is broken in. I would say the numbers dont sound that far off though given the heat, humidity and lack of break in.
  11. LVChefCC
    LVChefCC New Member
    Aug 9, 2013
    14
    Orlando
    cross country tour
    I am not disappointed about this initial result at all, I just posted up to show a baseline, the camset and llyods intake will be going in after the 600 mile oil change. And that will give the auto tune time to map all the cells for this set-up prior too the cams and hopefully will be faster to autotune the new cell set after the cams are in and the motors fully broken in.
    These engines are pretty stout,tho we arent expecting a world of change after the cams,id much rather have 10/15 tq. Over 10/15 hp especially on the low end on these bikes.
    we shall see ......
  12. Bill4Vendetta
    Bill4Vendetta Member
    Oct 30, 2011
    480
    14
    Owasso
    2012 Red Cross Country Tour
    I had the works done at the AVR last week. Lloyd's cams, air filter, adjustable timing gear, PC5.Dyno results...
    116.3hp and 114.25ft lbs torque!
  13. Coop
    Coop Member
    Apr 24, 2011
    58
    Lawton/Fort Sill
    2013 Victory Cross Country
    Bill4 I see you are from OK. So were did you get your bike from and who installed all of your parts?
  14. Easy_CCT
    Easy_CCT New Member
    Mar 18, 2013
    2
    Shakopee
    2012 XCT
    "I had the works done at the AVR last week. Lloyd's cams, air filter, adjustable timing gear, PC5.Dyno results...
    116.3hp and 114.25ft lbs torque! "
    Bill, I'm thinking of doing the same thing. Can I ask how much they charged you to do all those updates?
2013 victorty cross country dyno results
bassani road rage long dyno results
dyno victory road rage
power commander 5 dyno results
road rage dyno victory
victory lloyds cams dyno
victory road rage dyno
