Drive Belt Issues
Discussion in 'Victory Cross Country' started by cerobinson, May 5, 2017.
  1. cerobinson
    cerobinson Member
    Aug 20, 2015
    30
    28
    Ravenna, Ohio
    2015 Cross Country Tour
    So I started hearing a "noise" on my XCT while I was riding that I could hear over the radio. The only way to describe the noise is it is a "worble" over the sound of my pipes..
    Once the wife heard the same sound, off to a local Victory service department and it is suspected that the drive belt is loose and is the cause..
    My question is that with less then 10,000 miles on the bike, should the drive belt stretch?
    The back wheel has never been removed and no adjustments have been made after the first dealer service.
  2. ByteN2it
    ByteN2it Well-Known Member
    Mar 15, 2010
    720
    253
    '99 V92C & '09 Vision
    Once the belt is readjusted after the initial break period it should be good for the belts life. Are you sure it was ever adjusted by your dealer at the 500 mile service?
    • Agree Agree x 3
  3. Flyboy
    Flyboy Well-Known Member
    Aug 29, 2014
    6,770
    2,649
    Victory Boardwalk
    Yep, they could and really after tire replacement and make sure a final alignment follows the retension procedure and if you are unsure how to do the Dealer can. But, the adjustment is supposed to be made with belt dry and at ambient temp and no washing or moisture prior to adjustment. So I do my own...
  4. cerobinson
    cerobinson Member
    Aug 20, 2015
    30
    28
    Ravenna, Ohio
    I can only say that it was on the sheet of what was done after the service. I just got confirmation from the current dealer that it was loose and they adjusted it and the noise went away.. If it comes on again, I will get the belt replaced.
  5. ByteN2it
    Mar 15, 2010
    720
    253
    I'm guessing it was never readjusted. No need for a new belt for a long time-provided it was adjusted correctly. This is why you need a lift & a service manual.
    • Agree Agree x 3
  6. cerobinson
    cerobinson Member
    Aug 20, 2015
    30
    28
    Ravenna, Ohio
    Its on my bucket list!!!!
  7. vision_nut
    Aug 15, 2011
    5,953
    516
    vision
    your belt is good for 80K if not more.
    your belt like he said has to be adjusted when cold.
    When riding and you hear the sound pull in clutch if sound stops its the belt for sure.
    Have you lowered the bike
  8. Old-Gramps
    Old-Gramps Well-Known Member
    Jan 29, 2014
    5,880
    1,629
    Australia
    2014 Cross Country Tour
    • Funny Funny x 3
  9. Half_Crazy
    Half_Crazy Well-Known Member
    Aug 23, 2008
    11,664
    4,416
    Great Mills, MD
    2006 Kingpin
    Why do you tell people this when Victory recommends replacement at 35,000 miles? If someone uses this info and runs a belt to 75K miles and ends up on the side of interstate with a broken belt, 500 miles from home, wouldn't you feel bad?
  10. 40caliber
    40caliber Active Member
    Nov 10, 2013
    333
    105
    Hollis, NH
    2012 Victory CCT, 2003 valkyrie
  11. PDXLaserGazer
    Jun 3, 2013
    1,205
    337
    Portland, OR
    Mine says 30k ('13 XC), is the vision 5k better?
  12. FoFo
    FoFo Well-Known Member
    Jun 14, 2016
    971
    522
    Fort Worth, TX
    2010 Victory Cross Roads
    My CR is at 30k.
  13. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    3,555
    1,365
    South Florida
    2011 Cross Country
    35k and new belt !
    Is there a longer lasting belt option ?
    A drive shaft conversion kit ?
    Lol just kidding.
  14. PDXLaserGazer
    Jun 3, 2013
    1,205
    337
    Portland, OR
    Coincidentally, there is a shaft conversion available. It goes in a v-twin and comes out an inline 6. The tank badge changes a little from a V to a wing, you lose a little bit of the exhaust sound, some of the coolness factor but you can set the autopilot and take a nap. I hear you can get it done for just under 24k these days.
    • Funny Funny x 3
  15. Bujee1
    Bujee1 Well-Known Member
    Jan 3, 2015
    2,114
    1,080
    SoCal
    2011 Cross Country, and 2016 Cross Country Tour
    I have been following the belt threads and have not seen a story when a belt failed on a Cross Country. You are widely respected by many on this forum for your knowledge of all things Victory. So I ask this question with all due respect: Have you heard of or seen a belt fail on a Cross Country that has been properly maintained with less than 80,000 miles?
    I ask because my bike has 53,000 on the same belt and every time I take it to a mechanic I trust, he says keep going, it's fine. Of course, I check it regularly for rocks, tears and cracks in the teeth. I also check the belt tension at every tire change.
    • Like Like x 3
