Cross Country Tour Stereo upgrades
Discussion in 'Victory Cross Country' started by bfdvp71, Sep 26, 2012.
  1. bfdvp71
    bfdvp71 Member
    Jun 18, 2012
    88
    Broadway, Virginia
    2013 Victory Cross Country Touring Boardwalk Blue
    I've seen numerous threads on stereo upgrades and they are all over the place. Im trying to get as much information as possible and to upgrade for the best cost/value/quality/sound; What are some of the setups that you as other members have installed in your own bikes ? Cool amplifier operation along with use of 6.25" speakers is definitely a priority for this install. Looking to keep all the components that need to be purchased under around 800 bucks or so.
  2. smokeXC
    smokeXC Member
    Aug 28, 2010
    163
    3
    State College
    Cross Country
    For that kind of $$ you can do most anything reasonable you want.
    My set up is a Rockford Fosgate PBR300x4 that I got off Amazon for $165 and free shipping.
    I now have 6 1/2" speakers in the front. SORRY, I honestly forget at the moment what kind they are. Polk ???? I do remember they were $139 on amazon and that was a great deal and free shipping as well
    I have the XC so I only need 1 pair of speakers but you will need 2 pair. I would say the 6 1/2" in front with adaptor rings and Polk 5.25 Dxi in rear. This amp is 4 channel so front and rear work great in the bike.I installed everything in a buddy's XC Tour and it just rocked. Sure someone will always push the envolope but the above is very very good and reasonably priced.
  3. TheBucket
    TheBucket Member
    Apr 22, 2012
    213
    24
    Mpls
    2012 XCTour
    Man o Man...I'm so torn on this. I put in the Kicker speakers from Ma Vic in my '12 XCT. Then I had a ARC Audio 125.4 put in. Here's my take.
    Sound is better and louder - no question. Problem is that at anything over 70 mph, you lose so much bass, and have so much road/engine/exhaust noise, it's almost worthless. I'm trying to decide if a speaker upgrade will improve that or not. The guy at the install shop said he could pump 1000 watts thru the speakers, and at those speeds, it would all sound like crap.
    Really not sure if it's worth it or not.
  4. bfdvp71
    bfdvp71 Member
    Jun 18, 2012
    88
    Broadway, Virginia
    Was looking at a similar setup with the amp and speakers. Need some more punch than what the stock setup gives me. Thanks for the info...
  5. smokeXC
    smokeXC Member
    Aug 28, 2010
    163
    3
    State College
    Cross Country
    I was riding in a group ride back in July. A couple was on a Harley Ultra offset to my right rear. He and his girlfriend came up to me during a stopand ask me what radio station I was listening to? I said why? They said I have the loudest stereo on a motorcycle that they ever heard and they liked the music that was playing. They both said they could hear mine loud and clear from behind me. I laughed and told them it is my Ipod music I'm playing. They both laughed and said No wonder they couldn't find the station.Harley guy ask how I got it so loud and clear,............. so I had to let him in on the fact I had an amp under the fairing and 6 1/2" upgraded speakers in there as well. LOL
    BTW, you can only do 5 1/4" in the trunk without major work BUT the trunk acts as an enclosure and the bass is better. Simple test is open and close the trunk lid and listen to the difference. There are also a vendor maybe two now that have designed lids for our saddlebags that a 6 1/2" speaker mounts into. I think this is my next direction for more sound.
  6. bfdvp71
    bfdvp71 Member
    Jun 18, 2012
    88
    Broadway, Virginia
    Ive sourced out all the same components you've used but and looking at the Polk db series instead of the dxi. Both are marine grade and the specs are alike except for the top mount depth for which the db is less at 1 11/16th". Did you use the slim version of the dxi or the regular. Also where did you get your adapter rings ? Item number for them ?? When installing did you run all new speaker wire to everything ? Thanks again for all your info...
  7. CrazyDiavelRider
    CrazyDiavelRider Well-Known Member
    Jun 28, 2012
    1,978
    204
    Worcester MA
    White pearl Victory Vision Tour, AKA Starship Pegasus.
    was a stereo installer in my younger days, I saw a guy install a small sububwoofer in each of his saddle bags. I think they were in its own enlcosure to keep air tight. He only had a 100 watts mano to them but had them tuned perfectly. at higher speeds you need a bass boost and the front speakers need to handle at least to 60-80hz at low frequency and above. Most bike speakers only spec to 150hz and above. As long as the crossovers and gains are set corerctly they wont distort. here is a free tip,
    TIP TIP Behind your speakers on the fairings remove the speakers and fill with acoustical filler/foam makes them sound bigger and keeps the woofers in control. You can also use standard home insulation just make sure it is packed very loosely. Also consider another speaker if you have the room firing into the fairing , make this a mano mid bass signal and it will make your front speaker sound huge. Just little tricks I learned in my day.
  8. smokeXC
    smokeXC Member
    Aug 28, 2010
    163
    3
    State College
    Cross Country
    I don't know much for sure. I think speakers were regular depth. My buddy bought everything that was talked about here in the past for his XC Tour. I just installed it all. They were the 5 1/4" Dxi trunk mounted speakers.
    As far as mine goes, an XC with only 2 speakers, I don't have the box anymore. I can't for the life of me remember what they are. They are 6 1/2" though. All of my info on the rings are gone too. I did this a while back and just followed what folks were using on here and another Vic site. They were direct bolt up. Speakers to the rings then rings to the bike locations, very simple. I did find an old PM about the baffle enclosures. They were from Sonic Electronic. Got them online as well. AND GOOD TIP from above, I put some material in behind my 6 1/2's from an old bass enclosure from years ago. Not sure of the difference but I was told the same thing. It makes it better so I believed it and followed though and put a little in.
  9. TCB-1
    TCB-1 New Member
    Oct 6, 2010
    668
    4
    Eustis
    Have the Fosgate amp with Focal 6.5" speakers and I also used the sound matt inside my fairing..
  10. bikendad
    bikendad Well-Known Member
    Apr 10, 2009
    4,335
    331
    SE Michigan
    2010 Victory Cross Country
    RF amp here as well with 6.5" Hertz speakers, biketronic adapter rings had to be modified a bit. I hear the hawg wired adapter rings work better. The amp and speakers however totally rock!
  11. jvrydex
    jvrydex Member
    Aug 7, 2012
    45
    SW Michigan
    2012 XCT, Bride rides 2011 Vegas
    The trunk will fit 6.5 inch speakers... Victory offers that size in the upgraded Kickers. For anyone who gets them and is going to follow Vic's instructions oncutting out part of the trunk to fit them...
    STOP! Don't do any cutting! There is enough clearance inside the grille to allow the speaker with a bigger magnet to fit- I used closed-cell foam tape- the kind you get at the home centers. It had a sticky clear tape applied to it. Measure what you need to fit around the perimiter of the mounting hole, pull the protective backing and stick it, following around the perimiter of the opening. Locate the screw holes and poke through the foam. Place the speaker in the now padded mount and install the screws- Take care not to drive them all the way in- You want the foam to space the speaker magnet away from the area they told you that has to be cut. So far, no ill-effects from not following directions- on the plus side, my trunk doesn't look all hacked up!
  12. hmd520
    hmd520 Vendor Supporting Vendor
    Aug 19, 2010
    1,398
    208
    Tucson
    We are currently working with Hawg Wired to develope a true plug and play system. This will have all the hardware and amp brackets included in the kit. It will have capability of being a 4 channel amp(so your choice 2 or 4 speakers). The speakers are 6.5" and come with cross overs. We should have something real soon .If you have any questions give me a call.
    Mike
  13. Potty
    Potty Member
    Jun 4, 2012
    53
    6
    Up North
    2011 Cross Country
    I tried to update my speakers with a Kicker 100 watt 2 channel amp with a pair of Polk dbx's. I installed the speaker adaptor rings with speakersand I couldn't get the fairing back on the bike then. I looked and looked and there wasn't any way they were going to work. I don't remember what brand the adaptors are but they wouldn't work for me. I would like to see some pictures of the install with the fairing off.
    I then went to Walmart and bought a $40 pair of Pioneer speakers and they soundmuch better then thefactoryKickers.
    Anyonelooking for a 100 watt Kicker amp, 2 channeland a set of Polk dbx's give me a shout. Or if someone has some insight I"m more then willing to listen.
  14. kevinx
    kevinx Well-Known Member
    Sep 1, 2009
    3,104
    632
    1955 Hyda Glide
    G[​IMG]
  15. kevinx
    Sep 1, 2009
    3,104
    632
    1955 Hyda Glide
    Sorry text did not work. Bolt in compact digitall amp with no heat worries, and great sound. Whole package for $469
stereo speakers upgrading for victory cross country tour
upgrade radio on victory cross country
victory cross country audio
victory cross country audio upgrade
victory cross country radio
victory cross country radio upgrade
victory cross country speaker upgrade
victory cross country stereo
victory cross country stereo upgrade
victory cross country tour stereo
victory motorcycle audio upgrade
victory stereo upgrade
