Clutch cable help
Discussion in 'Tech Q&A' started by TN_Kingpin, Apr 22, 2013.
  1. TN_Kingpin
    TN_Kingpin New Member
    Apr 19, 2013
    9
    2006 Kingpin Deluxe
    I've read through all the related threads I could find and unless I've missed it, I haven't been able to find the answer to my questions. I'm new to this forum thing as a whole, and this one in particular. So, I have 2 questions, the first is that I think my clutch cable needs a minor adjustment and I've located where to do that, but not sure how. I don't want to do any damage by trying to turn something that isn't supposed to be turned. If someone could explain this to me I would appreciate it, or tell me if I need to leave it alone and find someone with more experience to assist me. Also I'd be happy to explain the issue I'm having in full if anyone is curious, I just didn't want to create a bunch of uneccessary reading.
    My second question, is while looking for the answer to this question I came across several threads about clutch cables breaking. Could someone please explain to me where and how to lubricate my clutch cable as this seems to be the top recommendation to help prevent this. I have no knowledge of terminology, so would definitely need a "Barney-style" explanation.
    Thanks in advance!
    [​IMG]
  2. Work_Horse
    Work_Horse New Member
    Jul 15, 2012
    151
    1
    Grand Blanc
    2013 Cross Country Tour (Black)
    I've been riding on cable clutches since 1996 and have never had one break on me. That being said, I'm probably lucky too. Many people carry a cable repair kit, but I choose not to honestly.
    I very rarely ride alone outside of 100 miles from my house, but even still have a network of riders available (with trailers)should something like a broken clutch cable happen (thank you CVMA). Personally, I wouldn't worry about this issue too much while riding on a fairly new bike. But still, an upgrade to the hydrolic version should be considered in the future.
    I know I wasn't much help on this thread, butfelt the need to poke my opinion in.
    Be safe man.
  3. TN_Kingpin
    Apr 19, 2013
    9
    2006 Kingpin Deluxe
    I appreciate the input all the same Work_Horse!
  4. TN_Kingpin
    Apr 19, 2013
    9
    2006 Kingpin Deluxe
    Also I should have probably said, I have an 06 Kingpin with 11k miles on it. I think I have located one spot in need of lubrication and that is where the cable comes out to make the final stretch to the EZ Clutch. The coating is already worn off it, it looks like the angle isn't quite right, pulling the cable against the housing.
  5. tarzan
    tarzan Member
    Apr 29, 2012
    235
    8
    Chandler
    Victory Kingpin
    I have an 05 Kingpin and am on cable #6.55,000 miles on the bike. grease the cable ends at the lever and the trans.You need to take it loose from the handle. I remove the lever and clean the lever and the cable end. then grease the barrell on both ends of the cable and reinstall.
  6. TN_Kingpin
    Apr 19, 2013
    9
    2006 Kingpin Deluxe
    Thank you. At the transmission is where I can already see visible wear. I found a service manual, which will probably get me into trouble, so hopefully I can use that to figure out how to take it loose from the handle.
  7. ByteN2it
    ByteN2it Active Member
    Mar 15, 2010
    665
    200
    '99 V92C & '09 Vision
    The easy way to turn the cable loose is to take a crescent wrench and adjust it to fit over the clutch arm, engage the clutch with the wrench and remove the cable at the lever.
  8. victoryismine
    victoryismine New Member
    Aug 17, 2012
    224
    1
    Portland
    2011 Victory Vision ABS Vogue silver/Black w/stage 1
    Sounds like its time to come out with fly by wire for clutches.
  9. ajax
    ajax Member
    Jun 24, 2011
    494
    7
    Newnan
    2011 Victory Cross Country
    I wanted to go with the EZ Clutch but didn't for just this reason? I've read time after time where the alignment is off just enough to cause wear?
  10. Victorya
    Victorya Member
    Dec 24, 2012
    201
    16
    Temecula
    2016 XCT, 2011 XC, 2004 Vegas
    May I piggy back on this thead?
    I think my cable may need adjustment, what do you think? I normally start my bike in neutral but lately I have been starting her in 1st gear and when I do I notice even with the clutch pulled all the way in she lurches forward slightly. However I never notice her trying to creep forward at a stop once she is started.
  11. poptop
    poptop Well-Known Member
    Apr 25, 2010
    2,274
    396
    Vermilion
    09 Black Kingpin Prem rpw Thor 2 into 1. cams and ajustable timing wheel S+S intake and flash
    you have ajustment problems you need to set it back up so there is a bit of free playat the top
  12. jdelliott
    jdelliott Member
    Jul 25, 2012
    107
    Independence
    2004 Victory Kingpin
    I also notice the lurch on startup with clutch pulled in. Even if I give it a little gas (yeah, yeah, not supposed to blip, but I don't have stalling issues) at a light, it will want to move. Fact is, even in NEUTRAL, the vics (at least 04-05) will move the rear tire at 10mph if it is up off the ground on a lift. I think it is just the nature of the beast, and I have noticed it on other bikes as well.
  13. 1stVictory
    1stVictory Well-Known Member
    Feb 14, 2012
    3,958
    629
    Edmonton, AB
    2012 Pearl White CC Tour
    The rear wheel of my 98 Goldwing, while on the center stand, rotated in neutral when the engine was cold or hot. I was told they just do that. The oil acting as a medium, especially when cold, transferring the rotation of the engine's flywheel to the clutch. I rode that bike for 186,000 km (115,500 miles) and the clutch worked as it did like new when I sold the bike for the CC Tour. Don't sweat it.
  14. MONKEY666
    MONKEY666 New Member
    Apr 3, 2009
    609
    1
    Queen Creek
    H-D custom FXR, GSXR 1000, Buell XB12S
    Take my word on this: if all of a sudden you need a sizeable adjustment in your free play, it's the cable starting to seperate from the barrel and it WILL snap. Do yourself a favor and just get a Barnett cable now before you're stranded.
    Here's how to lube it since no one has really answered your question. Purchase a cable luber and some liquid graphite. Both are easy to find at bike shops. Remove your clutch lever at the bars, and the cable from the lever. (Notice the safety switch and don't break it when you reassemble). Put the luber on the cable and shoot the graphite spray down the cable till it's runs out the other end. Apply grease to the 2 barrel ends on the cable as well where they rotate. Inspect both ends for fraying. They are prone to snap off right where it attaches to the clutch arm. Yes I know from experience haha.
    Here's how to adjust it. Loosen the small nut on the part you pictured. Turn the adjuster till you have just a little free play at the lever. Don't take all the slack completely out, since your clutch plates expand when they warm up. I'd go with about 1/8"-3/16" gap between the lever and the perch.
    Hope this helped.
  15. TN_Kingpin
    Apr 19, 2013
    9
    2006 Kingpin Deluxe
    Monkey, thanks for your help. I had kind of answered my own question after not receiving any real help. I'm seriously considering saving up for a hydraulic conversion kit and skipping this whole issue being that I just bought the bike and this cable is ready to go. I want to be able to do extended trips without having to worry about a time bomb cable leaving me in a bad spot, even with a Sav-ur-ride. Hydraulic seems like a reasonable option being that it is close in price to a couple of replacement cables and alleviates the issue altogether.
how to adjust clutch on 2004 victory kingpin
