calibration card
Discussion in 'Tech Q&A' started by chavez, Jun 15, 2011.
  1. chavez
    chavez New Member
    May 28, 2011
    17
    new haven
    victory hammer
    Is there a difference in calibration cards if you have card for a slip on and get let's say RPW full exhaust? Does it affect the bike at all?
  2. mjw930
    mjw930 Well-Known Member
    Oct 23, 2009
    2,773
    58
    Ormond Beach
    Indian Scout
    The only calibration card you can get is from Victory (I don't think S&S is a card, just a download) and it's designed for use with their pipes. The fact that it works with aftermarket pipes is simply a byproduct. There's no such thing as an RPW specific calibration card. What you need to do is find a calibration that's a close to what you are installing as possible. Don't use a slip on calibration card when swapping the entire exhaust, find a calibration that's closer to what you are doing OR go to an aftermarket fuel controller instead.
  3. chavez
    chavez New Member
    May 28, 2011
    17
    new haven
    victory hammer
    Ok, thanks for the help. The advice is much appreciated
  4. Half_Crazy
    Half_Crazy Well-Known Member
    Aug 23, 2008
    7,486
    1,794
    Great Mills, MD
    2006 Kingpin
    If I'm not mistaken, the download card (Vic or S&S) allows you access the site where you can select the download of your choice to suit your combination.
  5. chavez
    chavez New Member
    May 28, 2011
    17
    new haven
    victory hammer
    So your saying the calibration cards aren't For specific exhaust? So I should be able to buy slip on card but have access to the stage one shotgun upgrade? Ok thank you...def needed help in this area
  6. Half_Crazy
    Aug 23, 2008
    7,486
    1,794
    Great Mills, MD
    2006 Kingpin
    Unless you have "Digital Wrench" software you can't do anything. The dealer will have to install the download. The card is most likely a password or site key to allow you to get ONE download. At least this is how I understood it.
  7. mjw930
    Oct 23, 2009
    2,773
    58
    Ormond Beach
    Indian Scout
    As I understand it the calibration card is linked to a specific download, it doesn't give you access to a library of programs. So, if you want the download for a Cross Country Stage 1 you purchase that specific calibration card. When the tech inputs the code from that card the Digital Wrench accesses the appropriate program, downloads it into your bike and registers that configuration against your VIN. From that point forward, if any dealer needs to update the flash on your ECM the Digital Wrench will pull the correct program based on what's stored against your VIN in the master system. Remember, there is no such thing as a "generic" download. Each download is qualified by the year and model of bike and the Victory components it supports. If you are looking to download a calibration to be used with non-Victory parts you'll need to know which Victory parts combination it most closely approximates. People such as Kevinx and others with intimate knowledge of the system should be the ones making the recommendation, not the internet and not a parts hanger at your local dealer.
