Bad Boy Air Horn Mounted on XCountry
Discussion in 'Tech Q&A' started by 2looney, Dec 21, 2012.
  1. 2looney
    2looney OT-CAN
    Aug 8, 2011
    875
    17
    Kitchener Ontario Canada
    2010 Cross Country Skulls
    I mounted a Wolo Bad Boy horn on my XC and would like to share it with you all.
    I took a 1/4" X 4 1/2" X 5 1/2" aluminum plate and made it my mounting bracket as you can see in the picture
    [​IMG]
    [​IMG]
    I fastened the relay switch to the backside of the plate to help hide the wiring. Next is to remove the side panel which you will find 2 threaded holes to mount the plate.
    [​IMG]
    With the plate predrilled i can now fasten it to the bike with 2 metric 8mm X 15mm allen screw which I had. The next picture will show the unit mounted in place.
    [​IMG]
    All conection that I had done I also used a dielectric grease to allow good connections while riding through different weather systems and climates. This is something I do with all electrical connections.Now the final picture with the side panel back on. I also plane to paint the mounting bracket black so it blends into that space a little bit more.
    [​IMG]
    If you have any questions let me know.
    Stay Safe
    Billy2looney
    • Like Like x 3
  2. bubba
    bubba Well-Known Member
    Sep 27, 2008
    4,509
    55
    Denver
    2006 Kingpin
    Good stuff...Nice Job!!!
  3. bikerbob
    bikerbob Active Member
    May 8, 2012
    1,380
    6
    Portage Lakes
    2012 Cross Country Tour
    I like it! Thanks for posting. I think I may do the same thing. I didn't want to tear into the fairing to mount it. This gives a nice alternative.
    Thanks again.
  4. OneThumb
    OneThumb OT-CAN
    Oct 25, 2008
    7,124
    65
    Nice install Billy
  5. 2looney
    2looney OT-CAN
    Aug 8, 2011
    875
    17
    Hi Bob, I also put my inline fuse in behind the other side panel where you would find the other fuses. With the Wolo they show a inline fuse from the battery to the unit. This way if for any reason you blow a fuse it is easy to access.
  6. flumpydog
    flumpydog OT-CAN
    Jan 21, 2012
    601
    4
    2011 Victory Cross Roads
    looks really good, so when you come over you will now be an expert to do mine LOL ;-)
  7. 2looney
    2looney OT-CAN
    Aug 8, 2011
    875
    17
    Aw long as you supply that magic serum in a bottle I will help you do the install. Lol
  8. El_Dave
    El_Dave New Member
    Feb 4, 2012
    701
    3
    Just outside Louisvillle, Ky.
    2000 Victory V92SC
    I'd supply the magic serum. But it's a loooooooong way to go for a drink!
  9. 2looney
    2looney OT-CAN
    Aug 8, 2011
    875
    17
    Did I hear "ROAD TRIP". Lol
  10. txchuck
    txchuck New Member
    Mar 14, 2013
    14
    Arlington
    2010 Cross Country (Skull Edition)
    I have a badboy horn that I installed on the ignition bracket, Made a simple bracket,[​IMG] [​IMG][​IMG][​IMG] then drilled a 5/16 hole on the left side of the ignition bracket, ran the wires under the gas tank & blam-o looks like it was made that way.having it on the side of the front cylinder means it stays cool an out of the way .
  11. 2looney
    2looney OT-CAN
    Aug 8, 2011
    875
    17
    Thx, for another alternative, Chuck and bythe way nice bike....
    Stay Safe
    Billy
  12. Dale88Jr
    Dale88Jr New Member
    Aug 6, 2011
    5
    2011 CrossCountry
    Do you have a picture prior to the first one that shows any of the wiring part of it.
    Many thanks
    Amanda
  13. Dale88Jr
    Dale88Jr New Member
    Aug 6, 2011
    5
    2011 CrossCountry
  14. 2looney
    2looney OT-CAN
    Aug 8, 2011
    875
    17
    Hi Amanda
    Give me a day or 2 and I will try and get something posted. Do you have a horn to install already.
    Stay Safe, Billy2looney
  15. merdinus
    merdinus Member
    Apr 3, 2013
    175
    2
    Bryant
    2012 Crossroads
    2looney.....
    Did you have a pattern that you cut the aluminum by? And would it be possible to get a copy of it. I like the way you mounted it "permanent/solidly". I'd like to duplicateit if possible.
    Thanks.
air horn for victory motorcycle
victory cross country air horn installation
victory cross country bad boy horn
victory motorcycle air horns
