Auto Tune Installation
Discussion in 'Victory Cross Country' started by samurrocket1, May 28, 2013.
  1. samurrocket1
    samurrocket1 New Member
    Mar 15, 2012
    23
    Chesapeake
    2012 Victory Cross Country Touring
    I had the dealer install the Bassani slip-ons, an H/F airfilter and the Power Commander V on the 2012 XCT. Since Power Commander did not have a map, the dealer went with the close enough map! I installed a the autone tune under the seat of the bike and ran it to an always hot wire and a swtich. Unfortunately, I have a mind like a still trap, nothing gets out and nothings gets in so I have left the swtich on several times and the returned to a dead battery. Can anyone give me some advice which wire to connect to under the seat so it is attached to a switched source along with which color wire? thanks, Eric
  2. StL_Mike
    StL_Mike Member
    Feb 23, 2012
    87
    1
    Valley Park
    2012 Cross Country Tour
    Eric, I don't have my instruction with me, but seems to me the AT installation instructions told me where to get power for the unit. - Mike
  3. samurrocket1
    Mar 15, 2012
    23
    Chesapeake
    The directions in the box said use a switched source. I never saw anything else.
    Thanks,
    Eric
  4. 11VICXC
    11VICXC theVOG.net Gold Supporter Gold Supporter
    Jun 21, 2011
    356
    2
    Rochester, NY
    11' Cross Country/14' Indian Vintage #953
    I just installed this on my 11' XC this past weekend. Under the left cover by the ECM is a 3 wire, 4 pin connector used only for the reverse installation. Tap the PINK wire on this connector for a switched 12V power source. The wide band O2s can draw up to 5 amps when warming up. This wiring information comes directly from the instructions.
  5. tonygiotta
    tonygiotta Member
    Sep 9, 2012
    611
    17
    Turlock, CA
    2012 Cross Country
    The tricky thing about this is that theinformation regarding where totappower for the ATis NOT in the AT instructions. They slip it into the PCV install instructions, complete with a nice little picture and everything!
    Look at Figure "B" and then check out the very last line on the very last page of the PCV install instructions.
    http://www.powercommander.com/downloads/19-009/install/pcv/eng19-009.pdf
  6. samurrocket1
    Mar 15, 2012
    23
    Chesapeake
    Thanks so much for the help.
    Eric
  7. StL_Mike
    StL_Mike Member
    Feb 23, 2012
    87
    1
    Valley Park
    I knew that I read somewhere, either the PC5 or autotune directions where to get power for the autotune module. I installed both of them at the same time which is probably why I didn't remember where I read it.
  8. WadCutter93
    WadCutter93 New Member
    May 28, 2014
    2
    Do you have any pictures of where you mounted it under the seat? I just got an Auto tune and am trying to find a place to mount it.
