Advice on best fuel controller for a Vision
Discussion in 'Victory Vision' started by supascape, Jul 5, 2013.
  1. supascape
    supascape New Member
    Feb 14, 2013
    9
    2005 Suzuki C90 Boulevard
    Hello everyone. I am looking for the best fuel controller option for my 2008 Victory Vision. I think that I have narrowed my choices down to the Lloydz gen 3 Victory fuel controller and the DynaJet Power Commander 5. I currently have the Witchdoctor Vision baffled Muscle Muffler installed and I would like to purchase the controller that works well with those particular pipes. My bike rides really well now but I get the occasional pop during deceleration here and there and I would like to get rid ofit as much as possible. My gut says spend the extra money, get the Power Commander with a dyno. However, I am hearing some pretty good things about the less expensive Lloydz. Any advise would be welcome. Thanks in advance.
  2. Splinter
    Splinter Member
    May 31, 2012
    248
    2
    Norwalk
    2012 Crossroads
    Ive had bad luck with Dynojet stuff in the past. I have the VFC3 on my XR and I like it. very easy to install and program. It will do all you need to unless youre planning on major upgrades to the engine.
  3. Monkeyman
    Monkeyman Active Member
    Jun 11, 2012
    2,935
    14
    Peru
    None :(
    VFC works fine even with cams. (That's what KevinX installs at his cam parties.) The only times when you need the PC-V is a big bore kit, or adding gas or induction (turbo/supercharger). The VFC is 1/2 the cost of the Power Commander and is just as easy to program (unless you get the Auto Tune with the PC-V, which costs even more). Some people swear by the PC-V but I don't know why. Personally, I think a dyno tune is unnecessary. When Kevin does cam parties, he doesn't dyno the bikes. In case you don't know, there are 3 major players in the high performace/tuning world of Victory. There's Lloyd Greer (aka the Victory Godfather), Rylan Vos (The Vic Shop) and Kevin Cross (aka KevinX). The latter 2 will do "cam parties" where, assuming you have a total of 4 bikes, he will come to you and install cams, top air filter, VFC and timing wheel, all for around $1450 (including labor).
  4. conklij
    conklij Well-Known Member
    Oct 30, 2011
    4,096
    380
    Daytona Beach
    2012 Victory Cross Roads
    Don't forget Kyle Crandall of KMC Powersports in RI. Kyle is a Lloydz certified mechanic and is the guy you will find at all of the bike rallys with his dyno trailer installing Lloydz performance parts. He knows his stuff and is a class act to boot.
  5. Monkeyman
    Jun 11, 2012
    2,935
    14
    Peru
    None :(
    I only sort of forgot Kyle. He's not as much of a big name as the other 3 (lack of advertising?) so I accidentally omitted his name. He needs to get out there more. :)
  6. Keith Grey
    Keith Grey Grouchy Old Member Gold Supporter
    Aug 4, 2010
    5,727
    1,020
    2010 ABS Vision
    Had both, and prefer the PCV. It gives you the ability to add an auto tune module. And I am just not as good with the VFC-III AS I was with jetting carbs. If you are getting a dyno tune, perhaps letting the tuner select will be best. Unless, there is any possibility of future improvements or the attune module in which case do the PCV. Keep in mind that Lloyd has a much better history with replacing bad parts and fixing issues, and Power Commander sells enough units that they will have more bad press ( based on volume of sales) and a more corporate approach to replacement or repair than Lloyd does. Good luck. Kg
  7. conklij
    Oct 30, 2011
    4,096
    380
    Daytona Beach
    Lloydz certified mechanics:
  8. conn-e-rot
    conn-e-rot Active Member
    May 31, 2012
    1,218
    12
    Conneaut
    2009 Vision Tour Premium
    I would check with your local tuner and see if he will tune it with the vfc3 I had asked the guy that had tuned my zx14 and he only does power commanders.
  9. iabob
    iabob Well-Known Member
    Dec 20, 2010
    8,197
    1,307
    Des Moines
    Victory Kingpin and Victory Vision
    If you like the way it's running be careful not to fix what isn't broke. Lloyd's IAV valve for 77.00 is easy to DIY and reduces popping on decel. But if you're determined to go fuel controller the I would get the VFC-III and with the money saved vs PC-V get the upper intake to go with the VFC. Now you can tune out the popping and tune in some more giddy up.
  10. TX2wheel
    TX2wheel New Member
    Mar 10, 2013
    164
    Houston
    Looking,,,
    Makes no matter, but it looks like Dobeck'does notsell' it's stage 3 and 3.5 units,,, they are sold by Electronic Jet Kit / EJK. Appears Lloyds has an agreement with EJK (or Dobeck) to cover the Victory line. so 'VFC' was born...
    Not familiar with the current generation of Dobeck/EJK/VFC.
    PCV has precision tuning down to a science, but all the science in the world is worth nothing in the hands of an unqualified tuner.PCV can alsotune up to 4 cylinders individually. Nice, if you live and die by .001 seconds,,,
    I went PC III / full Dyno tune on each cylinder with the old VTX. Done by the VTX (and many other bike) Guru Johnny Cheese. Excellent!
    Next bike gotthe O2 version of the Cobra tri-pot, as I didn't need tuning down to a knats a$$, and I could quickly and easily gone back to all OEM for long hauls/mpg. (Bike was 'near-stock')
    So, what does the 'average' rider need for a tuner?Whatever the rider and/oror his tuner/technical advisor(if he has one) are comfortable with.
  11. Gossamer
    Gossamer Well-Known Member
    Oct 13, 2008
    2,309
    105
    Victory Cross Country Tour
    Currently running the VFC 3 with my bike. Cams, intake, timing wheel, recored pipes.
    Have my auto tune sitting in a drawer while I wait for the PCV to show up.
    The VFC is fine for raw tuning. It'll do the job, you'll run good, make decent horse power.
    The PCV is more precision tuning, it recognizes front and rear, throttle and rpms.
    The PCV won't necessarily get you more power, what will it do is fine tune your bike to make sure the power delivery is a smooth as possible.
    I've got some burps in mine that I can't seem to get out of with the VFC so I'm trying the PCV and auto tune route.
  12. vision_nut
    vision_nut Well-Known Member
    Aug 15, 2011
    3,870
    206
    vision
    You say it runs good and now and then a pop. Un hook your 02 sensores and I'll bet it goes away and you can save the money on a tuner
  13. Steelvic
    Steelvic Member
    May 21, 2013
    33
    Malden
    '02 TC '10 Vision 8 Ball
    All I can tell you is that I visited Lloyd at his shop a few weeks ago for some work and here's how it went down. Told him I wanted his top filter, adjustable timing gear, Idle air valve and either a VFC3 or Power Commander 5 to go along with a set of Ness Big Honkers and a dyno tune on my Vision 8 Ball. The only other option was possibly doing cams next year. Then I let him decide whether to go VFC3 or PC5. He suggested going with the PC5 - so that's what I did and I'm very happy with the results.
    Jim
  14. mrpresident
    mrpresident New Member
    Jul 22, 2010
    28
    2
    Sykesville
    11 Vision, Crimson Red
    Sounds good! I am having cams and pistons along with PC5 with auto tune done now by The Custom Shop here in MD. How do you like the big honkers? I have D&D 's that sound good but I want something louder.
  15. Steelvic
    Steelvic Member
    May 21, 2013
    33
    Malden
    I'll tell youi that the Big Honkers are not as loud as the D+D's on my TC, but I really like the sound of them when I get on her.
best victory fuel controler
do you need power commander with gen 4 on victory cross country
dynatech comtroller for 2008 victory vision
how to fuel a 2008 victory vision tube
lloydz victory fuel controllerinstsl on vic vision
victory vfc vision
