2013 Victory Vision Photos and Specifications
Discussion in 'Victory Vision' started by Andy, Jul 31, 2012.
  1. Andy
    Andy Administrator Staff Member Moderator
    May 5, 2008
    3,897
    48
    South
    Cobra Driver, Callaway Irons
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    2013 Victory Vision Tour Specifications
    ENGINE
    Battery: 12 volts/18 amp hours
    Bore x Stroke: 101 x 108mm
    Charging System: 48 amps max output
    Clutch: Wet, multi-plate
    Compression Ratio: 9.4 : 1
    Cooling System: Air/oil
    Displacement: 106 ci/1731 cc
    Engine Type: 4-stroke 50o V-Twin
    Exhuast: Split dual exhaust with crossover
    Final Drive: Carbon Fiber-reinforced belt
    Fuel Capacity: 6.0 gal/22.7 ltr
    Fuel System: Electronic Fuel Injection with dual 45mm throttle bodies
    Oil Capacity: 5.0 qt/4.73 ltr
    Primary Drive: Gear drive with torque compensator
    Transmission: 6-speed overdrive constant mesh
    Valvetrain: Single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
    CHASSIS
    Dry Weight: 851 lb/387 kg
    Ground Clearance: 5.8 in/148mm
    GVWR: 1414 lb/643 kg
    Length: 106.4 in/2702mm
    Rake/Trail: 29/5.4 in/137mm
    Seat Height: 26.5 in/673mm
    Wheelbase: 65.7 in/1670mm
    SUSPENSION
    Front Suspension: Conventional telescopic fork, 46mm diameter, 5.1 in./130mm travel
    Rear Suspension: Single, mono-tube, cast aluminum with constant rate linkage, 3.65 in/92.7mm, air adjustable
    Accuracy: This info was provided by Victory, but painstakingly formatted by The VOG. We sure hope it's all correct!
    BRAKES
    Brake System Type: Linked ABS
    Front Braking System: Dual 300mm floating rotors with 4-piston calipers
    Rear Braking System: 300mm floating rotor with 2-piston caliper
    WHEELS & TIRES
    Front Tire: 130/70R18 Dunlop D418F Elite 3
    Front Wheel: 18 x 3.5 in
    Rear Tire: 180/60R16 Dunlop D418 Elite 3
    Rear Wheel: 16 x 5.0 in
    COLORS/MSRP
    Gloss Black:
    USA: $20,999
    California: $21,249
    Canada: $22,899
    Two-tone Gold Mist Metallic/Bronze Mist :
    USA: $21,599
    California: $21,849
    Canada: $23,549
    Sunset Red & Black with Black Carbon Graphics :
    USA: $21,999
    California: $22,249
    Canada: $23,999
  2. Trekwolf164
    Trekwolf164 Well-Known Member
    Oct 25, 2008
    4,900
    137
    Washingtonville
    Victory Vision,Slingshot
    I am so glad I bought the 2011
    Silver/Black with graphics and HID light.
    The new colors just don't get me to excited except the all black
  3. Nessie044
    Nessie044 Well-Known Member
    Aug 1, 2010
    1,812
    104
    SF Bay Area
    2013 Vision
    Can anyone explain why Vic will not put black fork lowers on the Vision? It's inexcusable that they're not on the black Vision. Even the Sunset & Black would benefit by blacked-out lowers, IMO.
  4. alanATW
    alanATW Well-Known Member
    Jul 14, 2012
    4,936
    980
    2013 Sunset Red Vision
    I've read a lot of your posts with interest and recognize you are passionate about your ride. I laughed at this post. Of course you don't like any other color except black. Didn't you say in an earlier post you've never owned anything but a black bike? LOL
  5. vision_nut
    Aug 15, 2011
    5,559
    452
    vision
    So what did they do to get the extra 1/2 quart in ?
  6. Trekwolf164
    Oct 25, 2008
    4,900
    137
    Washingtonville
    True but when I lost Deer Crusher to the flood I was going to order the 2012 Vision in Blue.
    It was my Dealer that made me an offer I could not refuse on the Silver/Black
  7. Bigfoot
    Bigfoot Well-Known Member
    Sep 27, 2010
    17,767
    2,550
    Northeast Ohio
    2011 Vision
    That's the 1/2 quart that you can't get out when you do an oil/filter change.
    Once again, great job Andy. [​IMG]
  8. Freerider
    Freerider Active Member
    Jul 5, 2012
    529
    33
    Imperial, MO
    2012 Sunset Red / Black Vision
    Did they change anything?
  9. SpidermanOhio
    SpidermanOhio Active Member
    Jun 11, 2011
    1,091
    12
    Hudson
    2011 Victory Vision
    Could not agree more Nessie....that's why I sent mine to WitchDoctor and had them powder coated. But, it should come that way from the factory.
  10. Nessie044
    Aug 1, 2010
    1,812
    104
    SF Bay Area
    2013 Vision
    It's not like it's unprecedented. They do it on the ANSS Visions, how much extra would it cost Vic to do it on the others?
2013 victory vision
2013 victory vision gold mist bronze metallic
vic vision torque compensator
